Posted by Øystein (148.122.151.53) on July 25, 2003 at 19:38:41:
In Reply to: Re: Positive test-resaults ! posted by Rainer on July 25, 2003 at 16:45:15:
Hello Rainer !
First let me say that the 200 Joules I got is pure OU.
(If the program is correct though)
I have tested theprogram in various other configurations and it comes out 0, in other simple mechanical constructions.
I have made so many variations of the principle,that I can`t really remember the one in question, but I always make it come out OU ! Example : 1 Kg falls 8 m, 6 Kg raise 3 meter and the wheel also have gained some rot. / kinetic energy !
So far I have only constructed one big system starting with the BIG weight at the bottom, and the smaller at the top, to see how high the bigger can be pulled.
Then I monitor ALL potential and kinetic energy in the system, before and after the lift.
The resault can not be higher than ZERO /equal (says the laws of conservation of energy)
That was my purpose in the first place, and to find the most reliable, simplest and best way to use this principle.
When I find a pattern in "peaking" the resault, I will try to work out smaller systems that can be spaced around the wheel, and also give OU when the systems have some speed around the wheel (timing). I also try to end up with parts that I am able to build easily (Ex : A sliding weight that is pulled is NOT easy to make from wood, so I try exchanging it for levers etc..)
Also got nice OU from that, but timing and position was very crucial....
So far...
Øystein
: Hi Øystein
: .. is it ok to ask for details?
: How far jumps the big one up .. and how far has 'little' to drop for that. The 200Joule you get out of it .. is it enough to reset the arrangement?
: Just curiuous as ever :o)
: Cheers,
: Rainer
: : Hello, just wanted to tell all you Bessler fans, that I finally
: : achieved to do a really positive theoretical test (in WM, Working Model software)of my last "Bessler principle" attempt.
: : I was able to gain far over 200 Joules from one rotation.
: : The mechanism is just a principle yet, and not able reset itself for another revoulution, but was constructed to test an idea.
: : The idea is based on, How can 1 pound raise 10 pounds ? etc..
: : without doing it throug 1 : 10 leverage etc..?
: : 2 ways :
: : 1. Through Centrifugal force difference.
: : Tried it, and it does not work.
: : Rotational Kinetic energy is exchanged with
: : work against gravity etc..
: : 2. Through kinetic energy buildt up in the smaller mass.
: : seems pretty much the same, BUT, I found that a small
: : mass can make a BIG mass jump into the "air", and still
: : not "waste" all of its energy into the Bigger mass.
: : At a certain relation between the weights, the smaller
: : weights arm can hit an "anvil" and the weight can keep
: : moving ahead and be pulling the Bigger mass.
: : BUT because the smaller weight is pulling the Bigger at the
: : same time, the impact force (kinetic energy transferred
: : to the flywheel)is hardly reduced.
: : SO YOU NEED AT LEAST A SMALL AND A BIG WEIGHT, A FLYWHEEL, AN ARM,AN ANVIL AND A ROPE TO AT LEAST TEST THE PRINCIPLE.
: : I have not found the best way to implement it to a full repeatable/reset-able buildable construction yet, just found the basic principle.
: : Have a good summer !
: : Øystein
