Posted by Georg Künstler (217.2.168.143) on August 27, 2003 at 08:12:25:
In Reply to: Re: Perpetuum mobile !!! posted by Mikhail on August 26, 2003 at 22:30:02:
: : Hello,
: : They is true, the imbalance of the wheel would bring the increase speed.
: : The speed of the wheel, that I invented, must be stabilized, if speed not does not stabilize, it will increase indefinitely.
: : But, it not impossible, only Bessler with found the means of stabilizing the number of revolutions of its wheel.
: : Regards
: : Mikhail.
Hi Mikhail,
the technic Bessler used for his wheel to stabilize, was the pendulum outside of the wheel.
If you don't use this technic, the wheel goes faster and faster, until the swingging inside is out of rythem.
If you had discovered this, you are on the right way.
best regards
Georg Künstler
