Posted by ali (62.145.60.175) on September 21, 2003 at 22:51:37:
In Reply to: Re: MT138 posted by Georg Künstler on June 28, 2003 at 00:25:17:
: : Hi Georg,
: : What you refer to as 'weights' are in fact black dots depicted with white centres. Bessler used black dots with white centres to show pivot or hinge points, not weights.
: : Your theory about Bessler's wheel is certainly fascinating and it would be great to see you prove it out with a working model. How's your construction going?
: : Regards, ovyyus
: : : : Hi All,
: : : : On Bessler's so called 'toys page', (MT138 at http://www.orffyre.com/mt121-143.html) there are 5 illustrations labeled A to E.
: : : : E is obvious, so too is C & D. But A & B remain a little more mysterious. I've heard A & B referred to as a 'Jacobs Ladder', but I have my doubts about this because the depicted hinge points are not how a Jacobs Ladder works (a Jacobs Ladder typically uses fabric straps fixed around the segments) .
: : : : If A & B are front and side elevations of the same device or toy, then what is that Bessler trying to illustrate here? Any suggestions?
: : : : Regards, ovyyus
: : : Hi ovyyus,
: : : My oppinion is that in the middle of the beams are weights.
: : : This means, that as in my 'Drehmomentspeicher' excenterweights exist, which are
: : : accelerated, breaked on the wrong side. With this technic you are archiving the increasing resonace.
: : : You have a swinging system with increasing resonance.
: : : Again, the physic/mathematical solution is described in the book Physic for Ingenieure page 289/290.
: : : The ISBN is 3-519-26508-7. All working models of Bessler uses this principle. This
: : : is the principle Besslers stated.
: : : The way for free energy is free now.
: : : Best regards
: : : Georg Künstler
: Hi Ovyyus,
: construction is going very well, but because i am making the parts myself, it takes a while with my limited tools to complete it.
: I am trying to make in my construction as many as possible parameters variable. So I have build the big wheel with 53 cm in diameter now.
: the inner mechanism is varialbe in diameter, weights are variable, and now i am constuction a mechanism to make the springs also variable.
: With the help of the formulars in the physic book i can calculate all dimensions correct, but i can't buy a spring with a specific springconstant.
: Therefore, for my model i must do a calculation backwards. I must buy springs which are nearby at that point what I need, and then calculate the corresponding weights. This type of working is very timeconsuming. but be sure, the model is correct, and will be completed as soon as possible.
: Best regards
: Georg Künstler
