Posted by Georg Künstler (217.2.165.225) on September 24, 2003 at 01:42:54:
In Reply to: Bessler wheel theory part 2 posted by Patrick on September 23, 2003 at 20:50:59:
: To have a 'weight transfer' occur, intuitively it would be difficult for a device (sub-device) that is attached to the wheel to ‘sense’ when it is reaching the zenith or nadir since it is moving in concert with the entire wheel itself. Thus, a device, indicator or input, external to the wheel could facilitate such a transfer by reaching ‘within’ the wheel mechanism and altering the wheels' weight distribution. (example: imagine continually tapping a spinning wheel with your finger to keep it moving - obviously not our goal!). For aesthetics, practicality and to achieve our goal it intuitively makes sense to have this external input occur within the wheel itself but should not be attached to the wheel {since as previously mentioned ; this would necessitate an undue complex process}. Thus, a part of the total wheel mechanism must be fixed (Not Rotating!) and be able to effect/affect the redistribution of weight without undue friction. (the weight transfer effect must be greater than the sum of various frictions which may be occurring within the wheel). This 'external' ‘input’ from a fixed source must not be inputting energy or the primary purpose of the wheel is defeated; rather it must be a passive, (non-energetic or perhaps gravity driven) effect or adjustment. (example could be a fixed stationary peg that touches the wheel at some point.)
: To sum up, we need an external input for our wheel (no, not a nine volt battery!) [For a clearer example, take a look at drawing number 13 from Maschinen Tractate; imagine that the central 'anchor-shaped' weight is attached to the central axle via a roller bearing. This anchor weight stays vertical as the revolving weights pass over it; each weight is passively touched (twisted or adjusted) by the central anchor weight 'input' at the top and bottom of the mid-wheel mechanism].
Hi Patrick,
to have a look at the movements of M13, have a look on my
homepage http://www.kuenstler-energie.de and then M13.
Your analysis of the problem will help a lot of the Bessler comutity
to understand what Bessler did. It is not a Gravity wheel !!
Again and again, the physic and mathematics is known.
It is a forced swinging with a trouble force.(increasing resonance)
