Posted by Will Green (64.109.36.6) on October 11, 2003 at 17:35:49:
Hello
My name is Will Green I have a new motor design and the math has me perplexed. I am looking for third party verification as to the validity of the math as applied to this mechanical system. Can you please help me or refer me to some one who can?
Sincerely
Will Green
(920) 707-2511
Engine Math
In a fluid embodiment, this motor is 14 diameter, 8 cylinders, 2 pistons, with a 7 dia. crank shaft and 0.5 displacement, there are 3 active cylinders. In this example we are using the constants 450 psi cylinder pressure, rotating at 900 rpm. The above system is driven by a hydraulic fluid pump with an electric motor.
Constants
Displacement = 1/2 inch
Pistons = 2 diameter
Active Cylinders = 3
Starwheel Crankshaft = 7 diameter
Pressure = 450 PSI
Speed = 900 RPMs
A = Cylinder Area = pi*(r^2) = 3.14*(1*1) = 3.14
Ta = Total Area = A*active cylinders = 3.14*3 = 9.42
P = Pressure = 450psi
F = Foot Pounds = ft lbs = (crankshaft radius / 12)*4239 = (3.5/12) =.2916 * 4,239 = 1,236 ft lbs
F1 = Ta*P = 9.42*450 = 4,239 in second HP formula
C = Circumference of Star wheel = 7 * 3.14159 = 21.99
N = RPM = 900
D = Distance in 1 Min = (C*N) /12 = (21.99*900) /12 = 19,791in/12 = 1,649.25 ft
L = Starwheel Crankshaft Radius / 12 inches = 3.5/12 = .29 ft
With the above given; the following is 2 different HP formulas for work out:
1.) HP=F*N/5252 = 211.8 HP or = 158,002 W
2.) HP=(C*N / 12/60) * F1 / 550 =211.85 HP or = 158,040 W
What we need to do now that we have calculated the above HP formulas, we then calculate pump fluid flow & HP based on a volume of 12.56 cu in per rev || 900 rpm then convert that into gal per min, and use the above pressure at 450 psi
The total displacement per cylinder = Cylinder Area* Displacement - 1.57 cubic inches
The total displacement per rev = Cubic Inches* 8 Cylinders = 3.14*0.5*8 = 12.56 displacement per rev.
Total Displacement at speed = Displacement per rev* RPM = 12.56 * 900 rpm = 11,304 total displaced cubic inches
GPM = Total Displacement Cubic Inches / GPM Constant = 11304 Cu In / 231 = 48.93 GPM
With 48.93 GPM and a pressure of 450 psi we can compute pump HP work in.
The following are 2 Hydro HP formulas representing work in.
1.) PUMP HP=GPM*P / 1714 = 48.93 * 450 /1,714 =12.84HP or = 9,578.64 W
2.) PUMP HP=GPM*P*.0007 = 48.93 * 450 * 0007 = 15.41 HP or = 11,495.86 W
Efficiency work out / work in * 100 = 211.98HP / 15.41 HP * 100 = 1,374.56%
The efficiency of a machine, which is defined as the ratio of the work output to the work input, is always less than one, since some of the input is invariably wasted in overcoming friction. The element of time does not enter into the computation of work; the time rate of doing work is called power
The ability of a machine to amplify force is called its Mechanical Advantage. In this situation, the force is increased by a factor of 9.42. Mathematically, the mechanical advantage (MA) is equal to the force exerted by the machine (resistance force - Fr) divided by the force input (effort force - Fe). Thus the equation for mechanical advantage is:
MA = Fr / Fe
Fr = 4239
Fe = 450
MA = 4,239 / 450 = 9.42
Mechanical advantage is the ratio of output force divided by input force.
If the output force is bigger than the input force, a machine has a mechanical advantage greater than one.
Math references
These formulas are courtesy of Gulf Coast Air & Hydraulics Lion Hydraulics
Reference 1 http://www.gulfcoastairandhyd.com/formulas.htm
Reference 2 Courtesy of Sidener Engineering http://www.sidenereng.com/formulas.htm
Reference 3 MacDizzy© 1993-1999 http://www.macdizzy.com/formulas.htm
Reference 4 Efficiency formulas http://www.kent.k12.wa.us/staff/trobinso/physicspages/PhysicsOf/Wade/physics.htm http://www.reliance.com/prodserv/motgen/b7087_5/b7087_5_3.htm http://www.zoeller.com/zep/techbrief/JF1article.htm
Reference 5 Pump HP formulas see http://www.hfsindustrial.com/formulas/formulas.htm
Reference 6 HP and volumetric efficiency
Combinations in Sliding Contact", NASA TM-106348, DOE/NASA/50306-3, N94-15769, October 1993.
Nobel Laureate Richard Feynman and one of Einstein's protégés, John Wheeler, have calculated that there is more than enough energy in the volume of a coffee cup to evaporate all the world's oceans!
