Posted by Georg Künstler (217.2.167.135) on October 14, 2003 at 01:18:27:
In Reply to: I too, need some info posted by Jonathan on October 13, 2003 at 05:20:54:
: Are there any techniques you guys can think of that will hasten my construction of conical gears? I prefer if the teeth can be epicycloidial, I have an easy time designing those. It has occurred to me to use two different sized disks and dowels/spokes connecting their perimeters, but it makes the teeth design complex, which means I'll probably screw it up.
Hi Jonathan,
if you must use gears, you are on the wrong way. How long does it take for a
carpender to cut gears ? I assume with Besslers technic more than a night.
I made the gear way before, now I am only using rollers carrying an eccentric weight.
With this rollers, you can have a higher (breaking)resistance and
you can act with an oscillating force. Look at my homepage under COG and resonance.
