Posted by Jonathan (68.14.212.239) on October 23, 2003 at 01:32:12:
In Reply to: Bessler wheel theory part 5 posted by Patrick Doucette on October 22, 2003 at 23:48:23:
I want more details on this one too!
: One of the statements Bessler makes concerning the inner working of his wheel is the following familiar statement. "these weights... are... co-ordinated in such a way that... they (are) prevented from attaining their desired equilibrium."
: To this end/description we can propose several statements.
: After numerous experiments, I have decided to abandon the possibility of 1) directly interconnected weights; although I see no reason why this concept may not contain a contributory effect towards an actual complete solution.
: I have made progress, however, with the concept of, 2) the connections between the weights may be dynamically inter-connected. Examine the images below for example. (note: that this represents only the inner axle portion of the wheel.)
: As weight is applied to one side of the spokes during the 'down' cycle, a portion of the weight is re-distributed to the opposite side of the wheel giving a contributory driving 'up' impetus to the opposite 'paired' weight. The lever-action in the above diagrams is simplified and can/should be implemented in various ways using different designs to accommodate the required number of weights or 'sections' and to provide the desired proper/efficient re-distribution of weight. In particular, a design using curved spokes and a more efficient direct lever mechanism around the axle/fulcrum may display action that is conducive to progressive rotation.
: (I am still working with independent/gravity-driven 'pegs' as the key input and hopefully will be able to provide some theoretical & practical ideas in that area in the near future.)
: Best regards to all,
: ---Patrick Doucette
