Question for J.C.
Posted by Michael (199.60.107.1) on October 25, 2003 at 11:30:07:
Hi John,
I've discovered a decoder of sorts, that on everything I've tested it on so far. In fact sometimes in a very suprising way. I have a question for you, that would help in the validation process. But you need to consider the question thoughtfully and try to answer as honestly as you can-if you don't mind. I applied it to a part of your writtings on your web site. The section I applied it to states that the cohesive factor of your book, the values that pull it together; that is as a solid material ie. core of the book, is the wheel. The illuminated part of the book, that is the part that is most prominate-is the idea of the code. Okay so no biggy here, anyone can ifere that this might be the case. But I haven't read your book, and this is from applying this formula. What I want to ask you is, during the time of writting some of the main text of your web site, or even previously, or even until now, did you feel that the wheel was your wheel? I'm not asking you if you felt you were Bessler (though you may indeed have wondered if you had been), but rather since you've become so immersed in this subject for so many years, do you feel so close to it as to consider it (via your psyche) your wheel? Because the words MY WHEEL were prominate in connection with THE CODE.
mike
