Posted by Georg Künstler (217.2.164.91) on October 26, 2003 at 08:40:11:
In Reply to: COG doesn't work? posted by Jonathan on October 18, 2003 at 02:52:47:
: I think that I've determined that the COG device shown in simplified animation in the upper right corner here:
: http://translate.google.com/translate?u=http%3A%2F%2Fwww.kuenstler-energie.de%2F&langpair=de%7Cen&hl=en&ie=UTF-8&oe=UTF-8&prev=%2Flanguage_tools
: doesn't work. I made a simple model out of legos and there was no overbalancing. If I did recreate it succesfully, then I think the reason it doesn't work is that though the weight is eccentric, it's forced to exert its weight at the pivot regardless of postion. If this is true then the device should be no different than having the same length arms shown with same weight shown (but uniform density, which is different than shown) and masses connected at the same pivots as shown. This is what the experiment seems to indicate.
Hi Johnathan,
If you say, COG doesn't work, you are on a wood way.
Please show your experiments what you did,
and I tell you what you did wrong with your test.
Understand the resonance page first, before you invest more in
models.
