Re: VERY INTERSTING IDEA
Posted by Jonathan (68.14.212.239) on October 26, 2003 at 16:53:10:
In Reply to: VERY INTERSTING IDEA posted by Michael on October 26, 2003 at 14:24:44:
I think this is very interesting, I'd like to hear more! Aslo, I have been interested in Tesla's work and I have become aware of an electromagnetomechical device which may use special cicuit topology to beak Lenz's Law.
: I bought an electric pump used to blow up an air matress recently, and it sucked. So I traded it in for a coleman pump, and it worked MUCH-much better. The interesting thing about this is they both have approx the same voltage, I'm not sure of the amperage, and the designs are very different. The first one looks like a standard motor-generator design, the coleman looks a lot like Tesla's fluid pump design. A design he felt was able to give out five times the amount of power to what it takes to run it (I believe) if it was built properly. It got me thinking. The problem withg centrifugal force and singular items(weights ) is as a weight is pulled to the outer edge it's velocity potentialy increases, so the energy needed to drive it also has to increase. This isn't a problem with a disk using water, because the mass in the disk never changes, even though it is constantly being expelled from the outer edge. In the case of an overbalanced wheel using weights if one was designed so the ascending weight was driven towards the axel, at the same velocity as the descending weight, and if done at a fast enough velocity, it could be thown with enough force to start again at the top of the wheel. The benifit of this from a leverage perspective is as it is being forced to move to the axel the wheel is getting lighter on the ascending side. And I'm wondering if this was the real motivation of schauenberger. I don't believe Implosive energy was the real agenda, but was possible a code or a means to divert attention to the real goal. This set up could cover some of the saying pointed out regarding Bessler.
: The weights fell upon curved boards. The ascending weight was made to be closer to the axel than the descending weight. And a few others I can think of. What does everyone think about this?
: Regards,
: Michael
