Posted by John Collins (194.164.232.108) on October 31, 2003 at 02:08:45:
In Reply to: Re: Russian web site posted by Jonathan on October 31, 2003 at 01:13:41:
Thanks for that Jonathan - good work. I'll have to study it now to understand it.
John C.
And here is the last of it, I haven't even gotten to read it yet, it is long. It has pictures, so they may be too small or nonexistent and you'll have to got to the site(Edit:yep, no pics, so I'll indicate where they should be):
: Property of a cross to generate pulses of superindividual energy.
: Opening concerns to physics, is concrete to mechanics.
: Well-known, that Perpetuums mobile it does not happen, and by definition of a science, cannot be. The law of conservation of energy is unshakable. In any ideal mechanical device the resulting sum of forces after any transformations, on an output of the device, finally, is equal to zero. In any generator or the converter of energy target capacity cannot be higher than initial capacity. In the real device target capacity less entrance due to counteraction of forces of friction.
: The essence of opening consists that the device consisting of two crosses (diagonals of squares), planted on an axis of the rotation, connected among themselves a circuit or a cord having reliable coupling with crosses, at rotation of crosses is capable to generate pulses of superfluous capacity, or superindividual energy with provisional efficiency of 110 % on one device.
: Using my opening it is possible to develop and produce mechanical multipliers of capacity which for multiplication can be connected capacities consistently, and using which, the person can actuate muscular force any mechanical device which drive needs significant capacity, for example, the automobile.
: My opening incontestably proves close communication of a science and religion, proves presence at a cross not only spiritual force, but also physical.
: The cross is a symbol of eternity. My opening proves the validity of Christian belief, and, most likely, will lead to reconsideration of the Bible, will exclude its allegoric interpretation..
: My opening will allow to create a true Perpetuum mobile - (perpetuum mobile), an inexhaustible energy source which as I consider, Jesus Christ has brought to the Earth. The cross will for ever solve power problems of mankind and will considerably advance scientific and technical progress.
: The essence of opening consists that the device consisting of two crosses, planted on an axis of the rotation, connected among themselves a circuit or a cord covering them and having reliable coupling with crosses, at rotation of crosses is capable to generate pulses of superfluous capacity, or superindividual energy with the provisional, average efficiency of 110 % on one device.
: If at a round pulley the shoulder of the moment of forces has a constant at a cross the shoulder of the moment of forces during rotation smoothly, through 45 ° varies from the minimal, numerically equal 1/2 lateral faces of a cross, up to the maximal, equal 1/2 diagonals of a square, or length of the blade of a cross.
: It is established, that two identical crosses fixed on axes of rotation at any angular displacement on axes rather each other and connected by flexible transfer, freely rotate on axes, the same as also the round pulleys connected in a similar way. Also the similar transfer consisting of a square and round pulley freely rotates. It is the proof concerning uniform, almost linear movement of a circuit on a square pulley.
: Transfer with round pulleys has an identical, constant shoulder of the moment of the forces, equal to length of the perpendicular which has been lead from an axial line of rotation, taking place through the center of pulleys, up to a point podvesa a cargo, or is equal to radius of a pulley.
: Transfer with identical crosses, or with square pulleys, depending on a mutual angular arrangement of pulleys on axes, can have a variable, equally changing shoulder of the moment of forces (at zero angular displacement of square pulleys on axes, figs 1, a, b.),
: (PIC)
: Average which total value is equal shoulders at the moment of forces with round pulleys, or varia described cycle will be repeated 4 times. That is, one cycle of reduction ? increases in the moment of forces occurs for 90 ° turn. In the beginning on one square pulley there is a reduction, and on the friend increase in a shoulder of the moment of forces, then, at the further rotation of the device, pulleys are as though interchanged the position, ? where there was a reduction of the moment, - there comes increase where there was an increase in the moment, ? there comes reduction. Points of differentiation of half-cycles of reduction ? increases in the moments ? the positions of pulleys corresponding to position of these points have been found, represented on figs. 3b, 3d. These are positions of steady and unstable balance which arise periodically, through 45 ° turn of pulleys.
: From here follows, that if we shall continuously rotate transfer on a shaft alternately, through 45 ° there will be a positive superfluous moment and the negative superfluous moment, increasing from
: (PIC)
: Zero up to the maximal value and decreasing again up to zero.
: With the help of known mechanical devices it is possible to allocate and remove the positive superfluous moment from a shaft of selection of capacity.
: If to draw the schedule (figs 4) reflecting changes of target capacity we shall receive infinite sequence of positive pulses of the capacity growing up to certain value, and decreasing up to zero concerning any level determined by input power. The amplitude of these pulses will depend on weight of cargoes, or the brought capacity, and duration of these pulses will depend on speed of rotation of pulleys.
: The pulsation of pulses of capacity can be reduced installation on a shaft of a flywheel or the inertial mechanism.
: (PIC)
: The formula of opening.
: The device consisting of two crosses, planted on an axis of the rotation, displaced is relative each other on axes on 45 ° and connected among themselves is established by a circuit or a cord covering them and having reliable coupling with crosses, that, at application of forces to axes and rotation of crosses is capable to generate pulses of superfluous capacity, or superindividual energy with the provisional, average efficiency of 110 % on one device, caused by mutual-opposite change of shoulders of the moments of forces on both crosses.
