Re: Need Information
Posted by Patrick (65.93.158.186) on October 12, 2003 at 11:53:36:
In Reply to: Need Information posted by Ernest on October 12, 2003 at 11:26:20:
Hi Ernest;
This is an excellent question! I hope I can help. One of the materials I am using is a plastic disc 3 feet in diameter that looks the same as corrugated cardboard. This material is often used for signs and you can find it in any craft or home supply store (home depot). Unfortunately it will deviate more than 1/8" at the perimeter but since it is just for prototyping it is fine to start. The reason this is good material is because you need to punture it often with various axles, posts, pulley/lever support points etc. etc.
What you will find as you begin construction is this; 1) you get a brilliant revelation of how to build Bessler's wheel. 2) you put together your idea 3) it does not work as expected and you have to start over. Because of this cycle, you will be much better off using a plastic composite that can be quickly re-adjusted, re-punctured and manipulated. You should plan on having at least one or two strong 'revelations/inspirations' per week especially when first starting.
best regards--Patrick.
: I need advice and/or information on obtaining the right material to fabricate a wheel approximately 3 feet diameter.The material should be flat and maintain structural stability within 1/8" deviation on the perimeter and lightweight.
: Thickness is not a big concern as long as weight is kept to a minimum. Solid or composite material can be used.
: Thanks,
: Ernest
